Ir para o conteúdo principal
Repair and disassembly information for Brydge G-Type keyboards.
Why some keys are not working on My keyboard
Some keys are not working
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
If some keys on your keyboard are not working, there could be several reasons for this issue. Here are a few possible causes and troubleshooting steps you can try:
  1. Check for physical damage: Inspect your keyboard for any physical damage, such as spills, dirt, or debris lodged between the keys. Clean the affected area carefully using compressed air or a soft brush to remove any obstructions.
  2. Restart your computer: Sometimes, a simple restart can resolve temporary software glitches or conflicts that may be causing the keyboard issue. Restart your computer and check if the problem persists.
  3. Try different USB ports: If you are using a USB keyboard, connect it to a different USB port on your computer. Sometimes, the port you are using may be faulty, and switching to a different port can help.
  4. Test the keyboard on another computer if it's not a laptop ofc: Connect your keyboard to another computer and check if the problematic keys work on that system. If the keys still don't function correctly, it indicates a hardware issue with the keyboard itself.
  5. Update keyboard drivers: Outdated or incompatible keyboard drivers can cause problems with key functionality. Visit the manufacturer's website and download the latest drivers for your keyboard model. Install the updated drivers and check if the issue is resolved.
  6. Check keyboard settings: On Windows, go to the Control Panel or Settings and access the Keyboard settings. Ensure that the keyboard layout and language settings are correct. Make any necessary adjustments and test the keyboard again.
  7. Seek professional assistance: If the problematic keys persistently fail to work despite trying the above steps, it may be necessary to seek professional repair or replacement for your keyboard.
Remember to exercise caution and follow any specific instructions provided by the keyboard manufacturer. If your device is still under warranty, contacting the manufacturer's support team for further assistance may be the best course of action.
Esta resposta foi útil?
Pontuação 0
Click on the Start button
Pontuação 0
Adicionar a sua resposta
Ismail Umar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 1,861
