Ir para o conteúdo principal
A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
Y button does not work
The Y button does not work anymore. Already taken apart I just cannot tell what is wrong with it. Probably a trace connection, but in that case I cannot fix it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello Jay
If the Y button on your Nintendo Switch Pro Controller is not working, it could be due to a number of reasons. Here are some things you can try to troubleshoot the issue:
  1. Clean the button: Sometimes dirt or debris can accumulate under the button, preventing it from registering presses. Try using a compressed air can or a soft-bristled brush to clean around the button.
  2. Reset the controller: Try resetting the controller by holding down the Sync button on the back for 5 seconds until the lights start flashing. Then, try reconnecting the controller to your Switch and see if the Y button works.
  3. Replace the battery: If the battery is low or failing, it could be causing issues with the button. Try replacing the battery and see if the Y button starts working again.
  4. Check for physical damage: If the controller has been dropped or otherwise physically damaged, it could be causing issues with the Y button. Check the button and surrounding areas for any signs of damage.
If none of these steps work, it's possible that there is a problem with the button's circuitry or the controller's internal components. In that case, it may be best to contact Nintendo customer support or an authorized repair center for further assistance.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 473
