Ir para o conteúdo principal
Keyboard lights activation on my Laptop
My HP Laptop keyboard lights AMD PRO A6-8500B R5, 6 Compute Cores 2C+4G 1.60 GHz have not been working for some time and how do I activate them again.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
hello Mpho Rantao
To activate the keyboard backlight on your HP ProBook 430 G1, you can use the following steps:
  1. Press the "F5" key on your keyboard to see if it activates the backlight.
  2. If the above step doesn't work, try holding down the "Fn" key and then pressing the "F11" key.
  3. If the backlight still doesn't turn on, make sure that it is enabled in the BIOS settings. Restart your laptop and repeatedly press the "F10" key to enter the BIOS settings. Once in the BIOS, navigate to the "System Configuration" menu and select "Keyboard Backlight". Make sure it is set to "Enabled".
  4. If the backlight still does not turn on, there may be a hardware issue and you should contact HP support for further assistance.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mpho Rantao será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 90
Ao todo: 3,568
