Ir para o conteúdo principal
No signal after charging port repair
Performed a charging port repair on a iPhone 13 and after the repair there was no signal. I assumed that the device was damaged during repair and returned the original parts to the device only to discover the device could receive signal again. Did I overlook something in the repair? was my part defective? not sure what to take away from this at this point.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Maybe start off by checking if the phone has service with the old part, if it does then the new part is likely the issue. If not then then it's probably separate from the new charging port
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I ended up using the wrong part. Having the correct color for the charging port turned out to be the issue.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Camon Allen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 171
