Ir para o conteúdo principal
Screen for my phone
I've been trying to find a screen for a alcatel 7 model 6062W and I haven't seen it on here where would I go to get it??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Robert,
The big three places to get parts for smartphones are Amazon, eBay and AliExpress, although there are many other sites out there that specialize in electronics parts as well. A new screen for your phone seems to be pretty easy to come by; I found examples on all three sites like these.
Amazon.com: SRJTEK for Alcatel 7 6062 LCD Screen Replacement,for Alcatel 7 6062 6062Z 6062W / T-Mobile Revvl 2 Plus 2018 LCD Display Touch Digitizer Glass Panel Full Assembly : Cell Phones & Accessories
100%Tested Original LCD Display Touch Screen with Digitizer Full Assembly for Alcatel 7 / 6062 / 6062W / 6062T
Complete LCD Screen & Digitizer Full Assembly For Alcatel 7 6062 6062W 6062T
Any of those should work. I couldn't locate an iFixit-style set of step by step instructions for your phone, but I did find a YouTube video that looks reasonably usable.
alcatel 7 screen replacement
A couple of notes to be aware of; first, you'll probably want to keep better track of which screw goes where as you disassemble it. A magnetic mat is useful to have for that. Second, I'd suggest the use of heat to soften the adhesive prior to opening the rear case and separating the display from the frame. iFixit's iOpener works well, but you can get by with a simple hair dryer if need be. Careful with a heat gun; it's easy to overdo it and do some damage.
Also, you'll want to be sure and purchase some precut adhesive sheets for the rear case and LCD. To be honest, I usually buy a couple because they're all too easy to mess up. If you don't get them lined up right the first time you can't just pull it back off and try again; all you end up with is a tangled mess of adhesive. They're cheap and it'll save you from having to wait to put your phone back together while you wait to reorder if you don't have a spare.
Anyway, if you have any questions feel free to ask. Good luck with your repair, and let us know how it goes.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Robert Marshall será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 178
