Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
20 Perguntas Visualizar todos
PS3 doesn’t show anything on screen
please help me with my ps3 I’ve asked so many Reddit community’s and none of them could help me
Ok so My friend gave me this ps3 and he said the last time he checked the disc drive was not working but everything else was fine so I take it home and I turn it on and it works completely fine the disc drive was broken like he said but I don’t plan on using it. So like with every used console I get I took it apart and cleaned it ( it was VERY dirty) so I clean it and I try to turn it on and it doesn’t show anything on the screen and I know it’s not my tv and it not the hdmi cable because it’s like the ps3 crashed because the only way to turn it back off is too unplug the ps3. Now I did manage to get it to power on again and it worked fine so the I did a complete full hard drive format and it said it would take 7 hours so I went to sleep and when I woke up it was turned off and I can’t get it back on. Does anyone one know what the problem is and fyi the ps3 was not home-brewed
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Oh and I also can’t get it into safe mode
por
Adicionar um comentário
1 resposta
It could be the power supply or the connection. Do any lights come on when plugged in? I'd take it apart and test the power connections going to the power supply and the ones coming from it with a Multimeter. I'd also see if anything looks off, broken, or damaged. Take pictures and post them.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Ok I’ll take pictures but it’s not the power supply because I switch out the power supply with a working ps3 and it did the same thing, and yes there are lights on the ps3 when plugged in. now when I do turn it on the hard drive light blinks for a little bit then it stops and nether the network light (green) or the hard drive light (orange) blinks until I turn it off and back on again
por
Then from that, I'd say it's be a problem with the hard drive. Try switching it out.
por
Adicionar a sua resposta
Aj sullivan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 81
