Why is my coffeemaker leaking water from the bttom
Water drains from the tank and leaks out the bottom of the machine
Esta é uma boa pergunta?
Does the issue happen immediately upon filling the unit or only when operating? If it only happens during operation I suspect a hose has either failed or become partially detached internally. Alternately, the tank has a small crack which only leaks as the unit heats up.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 32
Duração total: 295
@roberttuff what model is your coffee maker?
por oldturkey03
