Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Perguntas Visualizar todos
Can I replace the disc drive or get an external disc drive?
The disc drive is bust, can i get an external disc drive for a Unibody?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
I personally like the LaCie USB/Firewire drive because I can use it on almost any Mac. The cost isn't bad and the durability is great. http://www.lacie.com/us/products/range.h...
Esta resposta foi útil?
Pontuação 2
Hi Gillian. You can buy Apple USB Superdrives as an external drive or you can also buy a cheaper USB drive that will work just as well. There are guides on here to help you replace the internal superdrive yourself, if you feel comfortable to do so.
Hope this helps,
Wes
Pontuação 1
Adicionar a sua resposta
Gillian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 171
