Ir para o conteúdo principal
Eighth generation of iPad, released September 18, 2020, available in 32 or 128 GB models. Model Number A2270.
13 Perguntas Visualizar todos
Can I swap an iPad-7 WiFi housing for iPad-8 WiFi housing?
Hi It maybe a confusioning question.
I have iPad-7 WiFi 32GB and an iPad-7 cellular 32GB but has a motherboard issue so it’s not working but has a perfect housing not bent
Also I have iPad-8 128GB WiFi working fine but housing is badly broken so there is water ripple on the screen. I have tried to bending back still water ripple on the screen
Do you guys think I took out of the mainboard from iPad-8 to put the board into the iPad-7 housing?
Do you guys think the it’s the same housing between the iPad-7 and iPad-8? also cellular as well?
plz let me know thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
hello there,
everything looks like same stuff but you have see all flexes ribbons. Some difference are possible. Basically yes :-) You can swap 8 into 7 housing but don't forget about small differences like holes, cam connectors etc (it can be few mm in wrong place).
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kyuho Lee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 42
