Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
243 Perguntas Visualizar todos
Can I use an iPhone 6s screen and digitizer on the se?
I have an iPhone 6s screen and digitizer that was never used on a previous iPhone. I also have an iPhone SE that has a cracked screen. Because they are the same size I was wondering if I could use the 6S screen on the SE? Are these compatible or are there parts that are compatible that could make this work?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
That's a negatory, good buddy. The iPhone SE 2020 is comparable to and based on the iPhone 8, so the two screens can be used interchangeably, but the SE won't take a 6S screen. Sorry, would be nice if it would've worked, but the mounting points, connectors and flex cables are all different and incompatible.
As a general rule, you're almost always safe in assuming a part for one phone won't work on another. There are a couple of exceptions where Apple reused one design on the next generation phone; e.g., the iPhones 5 and SE 1st gen and the iPhones 8 and SE 2020, but otherwise it's pretty much always a no for interchangeability.
The good news is that the LCD screens on these older phones are getting cheaper all the time; a quick glance around found a brand new screen for sale on Amazon for about $30 USD.
Amazon.com: for iPhone 8/SE 2020 [ 2nd Generation Screen Replacement Black 4.7 inch, Bsz4uov LCD Display Touch Screen Digitizer, Waterproof Frame Adhesive Sticker+Repair Tool Kit : Cell Phones & Accessories|new_window=true]
A thorough search may even come up with cheaper alternatives; I'd start with Amazon, eBay and AliExpress.
Esta resposta foi útil?
Pontuação 1
nope.
you can interchange iphone 5s screens with a SE 2016 (1st gen)
you can interchange iphone 8 screens with an SE 2020 (2nd gen) or 2022 (3rd gen)
Pontuação 0
Adicionar a sua resposta
Trevor Pressler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 91
Duração total: 1,034
