Ir para o conteúdo principal
Repair guides and support for Nextbook tablets.
not able to connect to a network
not able to connect to internet or wifi both are working on my other devices Nextbook model NXWIOQC332G Windows 8 THANKS
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
  • Select the Start  button, start typing cmd, right-click Command Prompt in the list, select Run as Administrator, and then select Yes.
  • At the command prompt, run the following commands in the listed order and then check to see if that fixes your connection problem:
    • Type netsh winsock reset and press Enter.
    • Type netsh int ip reset and press Enter.
    • Type ipconfig /release and press Enter.
    • Type ipconfig /renew and press Enter.
    • Type ipconfig /flushdns and press Enter.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
oralia castelo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 119
