Ir para o conteúdo principal
The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
12 Perguntas Visualizar todos
car stalls after running for 30 min.
I've replaced the fuel pump, fuel filter, and fuel pump relay. the only codes I get are for the cat. so I staight piped them both. still stalls after running for 30 min. starts fine after it cools down.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
@kijdfp08uw5vqvf what codes did you get?
por
PO463, PO420,and PO430
por
Adicionar um comentário
1 resposta
First off after changing all those parts did you reset the ECM? If not the auto still thinks the sensors are bad. Secondly it sound s like you original problem is electrical. Something is getting warm and going into default. Things like the coil and resistors for the ignition will not show on a code reader or self diagnostic reading.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mr.skeleton1969 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 84
