Ir para o conteúdo principal
Um controle de videogame sem fio, mais tradicional, produzido pela Nintendo para o console Switch. Número do modelo: HAC-013.
Left stick double clicks and gets stuck
My pro controller (2017) has a problem with its left stick that seems to double click when pressed down to the right. The right stick doesn’t do this. After opening it up, I noticed that the left stick has a loose part in the module that the right one doesn’t.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Thank you for this, I realised I had the same issue, glue didn’t hold so I use a small thin elastic band and wrapped it around the area to hold the loose part in place and now it no longer sticks:)
Esta resposta foi útil?
Pontuação 1
Eventually it's gonna fall off, but luckily it hasn't yet so gluing it into back into place should be easier. Use a small amount of a strong glue to put it back in position, if you don't want to replace the whole joystick. You can use your working joystick as a reference for where exactly it should be.
Pontuação 0
Adicionar a sua resposta
Juexis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 1,172
