Ir para o conteúdo principal
2.3L 4cyl or 3.0L V6, 6th Generation
428 Perguntas Visualizar todos
Cranks but won't start
2000 Honda Accord 2.3 cranks but won't start. I have replaced all the common issues ignition switch, ignition coil, etc. It is getting fuel has compression but the spark seems very weak. Tested the voltage to the coil and it is 3.3 volts. Any suggestions on where to go next?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
The voltage from the coil seems low. Not much experience with Hondas though. Is that the output voltage or what's coming into it?
Esta resposta foi útil?
Pontuação 0
1 comentário:
That is voltage to the coil
por
if you haven't done this yet, check your eng, fuse. my car would crank but not start & that was it. it's a 10amp
just now by will
Pontuação 0
Adicionar a sua resposta
Michael Leonard será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 228
