Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1502 Perguntas Visualizar todos
Replacement battery reported 100% for hours until it died
Now it doesn't charge at all I get the red battery with the lightning bolt when I try to power on while plugged in...obviously that should only happen for a few minutes and now it's been several hours. At first it reported 48% but charged to 100% in almost no time at all and stayed there until it ran out of power.
I only replaced the battery because I wasn't thrilled with the old one. Do I have a faulty battery?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
simple answer is yes. send it back. Try your old battery just to make sure you don't have a charging circuit problem but it doesn't sound like it.
Esta resposta foi útil?
Pontuação 1
2 comentários:
well I tried the old battery and now it's doing the same thing...I followed the guide precisely and I don't see how I damaged anything...any suggestions?
EDIT: after looking around the net (nothing that directly described my situation) Thinking it was possibly a software issue (hoping too) I did a restore with my old battery and when it finally booted to IOS it reported 97% and went to 98% a few minutes after. So I'm going to stick with my old battery until my next days off and try again with the replacement.
por
fingers crossed!
por
Adicionar a sua resposta
johndmcdowell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 179
