Ir para o conteúdo principal
Lançada no Japão a 12 de Dezembro, 2004, na América do Norte a 24 de Março, 2005, e na Europa a 1 de Setembro, 2005.
How to repair my psp when can't on power
my psp 1000 can't on and when my battery full also can't working....
Esta é uma boa pergunta?
Pontuação 8
3 comentários
I have the same problem too!!
I checked the batery, the power is connected to the motherboard.
por
How do I do that
that
por
i have problem with my psp start and l buttom
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Look at the DC port on the PSP. Does it have the little metal pin sticking out of the middle? It is also possible that the switch on the power board may no longer work. Pick any of the guides listed on here PSP 1000 and open the PSP up and see if you can hold the power board still, plug it in and try flipping the black switch to see if it'll turn on that way. Of course there is also the possibility that your power fuse is blown and that you have an interrupted circuit. check on here for much more info about that. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 7
7 comentários:
i will try it....thank for teching....
por
but me is 3006 modal...can help??
por
ginz.. this is the guide for you PSP 300x, I'm not sure that the fuse is in the same spot..If you need further help then please start a new question.
por
where the 300x fuse and i think board spot...
por
uuuum...Does this work on Non-Sony PSP...cause my PSP is not sony
por
Exibir mais 2 comentários
check the batery and the power on button.
Pontuação 2
I had seen on Youtube if you repeatedly push up the power button, it might turn on. Worth trying
Pontuação 1
Adicionar a sua resposta
ginz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 37
Últimos 30 dias: 131
Ao todo: 37,541
