Ir para o conteúdo principal
The Stylo 2V is a USA-exclusive slate-form stylus-enabled Android phablet released in 2016 for use on the Verizon network. Identifiable by model number VS835.
Why is my phone in a reboot loop
The phone will restart over and over again. Sometimes I can't even turn the phone on.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
you need to restore/recover android on your LG
i found a guide that will walk you through how to do this for your model
https://www.youtube.com/watch?v=bsxUBHox...
Esta resposta foi útil?
Pontuação 1
where is my comment, can anyone tell me
Pontuação 0
Common issue on this model (on many LG phones in general. The memory chip lose contact with mainboard, permanent fix is reball the chip. Temporary solution is heat up the phone with hair dryer on cca 60°C, the metal contact will lettle bit expand and Temporary will be there electric contact. I recomend this solution only for turn on the phone and také important data. There is no way to fix with any software becouse is hardware problem.
Pontuação 0
Adicionar a sua resposta
Joey Andersen (AwesomeWolfjj) será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 148
