Ir para o conteúdo principal
The Land Rover Defender (initially called the Land Rover Ninety and Land Rover One Ten) is a British four-wheel drive off-road vehicle developed from the original Land Rover Series launched in June 1948.
Why is my defender not starting
i have a 2001 land rover defender TD5 it has issues starting i have it at my local garage and they dont know what it is they have replaced a load of parts and have got it down to...
you turn the key and it does not turn over the engine and does nothing but when you spray quick start spray into the air intakes and then turn the key it fires straight up.
what is the issues please help!
when you turn the key the car turns over but does not start
they have replaced the pump
it only starts when you spray quick spray in the air intakes
it only turns over if quick start is sprayed
The parts they have check and replaced
test service
 Error-free machine-to-engine diagnostics
 Checking and measuring the electrical wiring with the multimeter / voltmeter, correct
 Rotation sensor replacement (PMS)
 Engine unit (ECU) replacement
 Checking all relays
 Fuel pump and fuel filter replacement
 Replacement of fuel pressure valve with pressure test verified with 4.5 bar pressure gauge
 Replacement of injector seals and washers
 Ignition replacement (by breakdown)
 With this, the engine does not start with a key, only with Start spray
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@archiestorey this " With this, the engine does not start with a key, only with Start spray" sounds like a fuel or timing issue. Does It keep running ones you use starting spray?
por
Adicionar um comentário
1 resposta
The td5 has a problem were oil seems into the ecu cabling this can cause a lot of issues ?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Archie Storey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 71
Ao todo: 753
