Ir para o conteúdo principal
The Bose SoundLink Micro is an IP67 waterproof Bluetooth speaker. This device includes a strap and micro-B USB charging cable. Model number: 783342-0100
Where can I find a replacement silicone strap?
The silicone strap on my Bose Micro tore apart and won’t hold on to stuff anymore. The Bose hotline said they can’t help. I tried glue, doesn’t work. There’s got to be a way to replace the silicone latch?
Esta é uma boa pergunta?
Pontuação 4
1 comentário:
I haven't had a problem with the strap tearing but the hook at the end no longer latches firmly and it pops out all the time. Trying to think of some good way to jury rig a new strap since the speaker is fine but it looks like there's no real answer but to buy a new one.
por
Adicionar um comentário
1 resposta
Same issue here.
The silicone strap is a little torn and keeps on clipping off my bike bar.
I'd like to avoid replacing the whole speaker.
Esta resposta foi útil?
Pontuação 0
2 comentários:
There are silicone cages available if that doesn't solve it a cable tie will 👍
por
Any TPE rated silicone glue should work ive just reattached my completely torn off strap back to the speaker with a fairly strong hold
por
Adicionar a sua resposta
Iwanttofixmystuff será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 513
