Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Perguntas Visualizar todos
Computer unexpectedly shutting down after battery replacement
I recently replaced my battery with an ifixit battery. I calibrated the battery per the instructions, but the computer is unexpectedly shutting down while I still have significant battery life remaining (i.e. 62%). It will restart immediately and will sometimes run for a decent amount of time and sometimes shut down again immediately. It seems to run fine while plugged into the power adapter.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
  1. Check battery health: Use a tool such as CoconutBattery (Mac) or BatteryInfoView (Windows) to check the health of your battery. If the health is low, it may be time to replace the battery again.
  2. Reset SMC: Try resetting the System Management Controller (SMC) on your computer. The steps to do this vary depending on the model of your computer. You can find instructions on Apple's website.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Weinberg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 25
