My left joystick is stuck plz help
my left joystick is stuck plz help i dropped it 1 day a go its will not go down
Esta é uma boa pergunta?
the stick seems broken and stuck so you will need too get it repaired
Esta resposta foi útil?
not sure if this applies to the switch lite, but I've found some joysticks get stuck if you push them too far. Try gently wiggling it and it might pop back into place
If it is stuck by a foreign object, remove the case and remove it. If not, the joystick may be broken. Just replace it
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 81
