Ir para o conteúdo principal
Does this use the same (abxy) buttons as the original GameCube
I wanna replace the buttons on one and I don’t know if I can use custom resin, 3d printed, or even injecting molded buttons for the original GameCube controller on it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
as long as you know what your doing, and use a guide, and have the right parts( and tools), it should work, and you need to make sure its meant for the wireless gamecube, and not a normal gamecube controller, as they could be very different inside. (although i don't think original buttons would work)
Esta resposta foi útil?
Pontuação 1
2 comentários:
Usually you can’t find replacement parts for 3rd party controllers online but I’ll look
por
you could if its a popular one, but you could maybe modify original ones(like sanding them down to the right size) if the controller is the same measurements as the original.
por
Adicionar a sua resposta
Nednal404 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 605
