Ir para o conteúdo principal
The iO, released in 2020 is an electric toothbrush by Oral-B. It is able to connect to your smartphone via Bluetooth and gives you realtime 3D teeth tracking. Model: Oral-B iO 9
Where can I source small repair parts? The neck gasket specifically
The seal below the metal ring on my io is split so water gets inside the body of the toothbrush. Can I buy a replacement for it? Or is there some other kind of repair I have to do instead involving silicone sealant or something?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Probably hard to get. I should use a silicon gasket.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Oral B (P & G) (Braun) provide no spare parts. It is disgraceful that a company can sell such an expensive item which they will not service and repair.
por
Adicionar a sua resposta
Kieran interior será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 504
