Ir para o conteúdo principal
Screen replacement question, note 10+
Hey all. I recently dropped my galaxy note 10+ and the back panel cracked along with the front. The front glass has a hairline crack down the right side. The touch screen portion still works but the bottom 2/3rds of the screen is white. I can only see the top portion of the screen. I am trying to determine what I need to replace this. I see some replacement screens for $20-30 and others for $250. Not sure exactly what I need. Any help would be greatly appreciated.
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
That $20-$30 replacement sounds like one of those glass only kits. Even if you were to successfully replace just the glass, your OLED panel is still damaged. So you'll need to order the more expensive option. If you can, order one with the screen attached to the frame. It makes the repair a lot easier. Looks like ifixit does sell an OEM display but order soon, looks like they only have a handful left.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
James Mishork será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 376
