Ir para o conteúdo principal
Repair and disassembly information for Samsung's flagship S20 Android smartphone, released in March of 2020.
Where can I find the Self-Repair Assistant app?
At the end of the Samsung Galaxy S20 screen repair guide, there is a document that guides you through calibrating the new hardware on your device. The document calls for a special app, and although it states the app can be found in the Galaxy Store or on the Samsung website, I cannot find it in either location. The repair guide does have a download link, but that version of the APK seems to be outdated because attempting to open the app shows the message "Try again after getting new version" and immediately closes.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Do can you get the link of this app? Has the problem resolved?
por
Yes, I was able to get the app to work (download link is on repair guide, https://s3.amazonaws.com/ifixit-assets/s...) by setting my date to 10-1-2022. Only calibration required for my device was a battery cycle count reset.
por
Any solution for the S20fe? After changing the screen I need to calibrate the fingerprint sensor and the app says not supported
por
Adicionar um comentário
2 respostas
Solução escolhida
Manually change the date in your phone to Oct/Nov 2022 and then try to open the app again.
Esta resposta foi útil?
Pontuação 5
You can also just update the app in the galaxy store
Pontuação 0
1 comentário:
It gets hot while using it
por
Adicionar a sua resposta
Ryan Sammons será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 50
Últimos 30 dias: 211
Ao todo: 10,826
