Solar T30 SLR+ calculator won’t charge
Can the battery be changed?
Esta é uma boa pergunta?
According to the manual: http://www.datamath.net/Manuals/TI-30SLR... the TI-30 SLR family has no batteries. It's powered solely by the solar panel.
If you put the calculator in a bright light does it turn on? If so, the panel might need to be replaced. Hopefully the old panel says what voltage it's rated for otherwise finding a replacement is going to be very difficult.
If it doesn't turn on, the panel may have simply detached itself from the circuit board. This would be properly repaired with a soldering iron but you might be able to get away with non-conductive tape.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 38
