How to reformat SSD
how to reformat external ssd
Esta é uma boa pergunta?
Open launchpad, click the "Other" folder and select "Disk Utility" (in the red box in the attached image),
and choose your external drive from the sidebar. Then, from the top bar, select erase. It will pull up a window with numerous options. If you just plan to use it for storage, just leave everything at the defaults and click erase. A pop up will appear asking you if you are sure. Tell its to go ahead and erase. It'll load for a minute or two and then, Presto! Your disk is erased!
Esta resposta foi útil?
disconnect and other storage devices, and try factory reset.
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 30
Ao todo: 1,538
