Ir para o conteúdo principal
Model M5884 / 400 or 500 MHz G4 processor
23 Perguntas Visualizar todos
m5884 dc internal broken -- how to change it
hallo... i've to change the dc connector...+ pole broken
is possible to have a guide... it is different from newer model...
i've the ac connector covered by a floor of circuit....
It's my first mac (bought in 2000) ... i would to my daughter the opportunity to play a little bit with him ...
I'm writing from switzerland and now i have my second mac... a MacBook Pro model 2009 .....
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Ifixit doesn't have the manual for this repair, but if you look here: PowerBook G4 Titanium Mercury Repair you'll see various other rapairs that will lead you in the right direction. This repair PowerBook G4 Titanium Mercury Logic Board Replacement will most likely suit your needs.
Esta resposta foi útil?
Pontuação 3
2 comentários:
thank you from Switzerland ....
i'll check ....
por
No Problem. Good Luck.
por
Adicionar a sua resposta
fausto será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,769
