Ir para o conteúdo principal
Apple AirPods are wireless headphones released December 2016.
20 Perguntas Visualizar todos
Can I clean AirPods using an ultrasonic cleaner?
Hi! I have had a pair of 1st Gen AirPods for a couple of years and as expected, they got clogged up with ear wax. Using a toothpick doesn't really do the trick as the wax is stuck in the mesh.
My question is: as I already have an ultrasonic cleaner, could I use it to clean them? Alternatively, can I use some cleaning alcohol on the mesh to try to get it out of there (PhoneFixCraft does this on YouTube).
I am afraid the liquid might damage it, but the alternative is buying a new pair, which would really be a waste as they work perfectly otherwise.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi
I really wouldn’t do this as ultrasonic cleaners are really good at putting holes in thin things
The speakers in your airpods have a thin plastic diaphragm that helps makes sound
When ultrasonic frequencies hit that chances are they will put holes in it,a way of demonstrating this is by putting a square piece of aluminium/tin foil in and watch what happens
What I would recommend is getting a small brick and a thing pick and cleaning them that way with isopropyl alcohol,that way is much much safer
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Andrei Covaci será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 58
Últimos 30 dias: 143
Duração total: 4,322
