Ir para o conteúdo principal
The sixth generation of Ford's Falcon line, including the AU, BA and BF series.
4 Perguntas Visualizar todos
Where is oil leak from
How to find where oil leaking from engine is
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Use a flashlight to check underneath your car and around your engine – telltale drips might lead you right to the problem. There are several common locations for oil leaks in your car, including: At your oil pan gasket. At your oil filter or drain plug
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
rob hutchings será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 158
