Won’t turn on and can’t reset
My Beats X won’t turn in and I can not reset it
Esta é uma boa pergunta?
Basically your battery is dead and needs to be replaced. I had the same issue with my Beats X in-ear headphones.
My Beats X were also 5 years old and I hadn't used them in more than six months, which probably made things worse and allowed the Li-ion battery to discharge completely.
I tried these options before confirming the battery was dead and needed to be replaced:
There was NO LED flashing after the factory reset. I removed the lightning charging cable and holding down the power button didn't start up my Beats X. After plugging in the lightning charging cable, the LED would flash white/ red/ white/ red and then stay on white.
Helpful Resources & Guides:
I hope this helps!
Esta resposta foi útil?
From what I learned it's all obviously caused by a faulty battery.
I actually found this guide on reviving a battery in Beats X.
If that doesn't work - here's a guide on replacing a battery and those guys offer a place to buy a new battery as well.
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 60
Ao todo: 964
