Ir para o conteúdo principal
Repair and troubleshooting information for the Kushlan 350DD, an electric wheelbarrow-style cement mixer.
1 Perguntas Visualizar todos
Barrel not spinning or frozen.
After storing for a few months, I flip the switch, and it is making a humming noise. However, the barrel does not spin, I cannot spin it manually before I take it apart, I was wondering if anyone had experienced the barrel, frozen or not spinning. I did check in the breaker button is not tripped.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
There should be a large capacitor on the motor. That could of gone over time. Most mixers are ran on a worm drive gearbox so you can't rotate the drum by hand. Is there any way to safely rotate the drive mechanism? It could be jammed with sitting.
Esta resposta foi útil?
Pontuação 2
2 comentários:
After testing, it appears to be a dead capacitor. Thank You!
por
@Joseph Galaska No problem, hope you get it working.
por
Adicionar a sua resposta
Joseph Galaska será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 250
