Ir para o conteúdo principal
Apple's March 2019 refresh of its iPad Air tablet, sporting an A12 Bionic processor and a 10.5" screen.
20 Perguntas Visualizar todos
iPad Not Powering on - Charger weird readings
Hello everyone.
My iPad Air 3 stopped working. I then found out that the display was defective and replaced it. After that, it fully boots up once. I let it charge to about 80% and then turned it off. Now it doesn't work anymore. When I plug it into the charger it shows 5V and rises to 2.2A charging power and then drops to 2V and 0A only to then rise again to 5V 2.2A. This repeats itself endlessly.
No Apple logo or anything like that appears on the display. I've already tried a reset via power + home button.
Board looks clean so far, nothing gets hot when the charger is on.
Any tips ?
Thanks and Greetings
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If the charger drops to 2v then I'd try another charger. Should be constant 5v at least.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
kilkenny91 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 64
