Ir para o conteúdo principal
A Bajaj Discover é uma marca de motocicletas da Bajaj Auto. Atualmente, existem quatro variantes da Discover: Discover 100 DTS-Si, Discover 125 DTS-i, Discover 125ST e Discover 150 DTS-i.
It can't start
My motor bike is not starting
Esta é uma boa pergunta?
Pontuação 18
13 comentários
Geoffrey Ouko what exact model is your motor bike? What have you checked? Do you have fuel? Do you have spark? Did anything happen to it or did this just start all of a sudden?
por
My motor cycle not start
por
Bettry charging
Palag problem
Indicetar chlu
por
البوجية لا تعطي كهرباء قوي
Translation Arabic - English
The spark plug does not give off strong electricity
por
@fgr31679 What make and model bike? What engine size? What year? What have you checked?
Translation
@fgr31679 ما نوع الدراجة وموديلها؟ ما حجم المحرك؟ ما العام؟ ماذا فحصت؟
por
Exibir mais 8 comentários
Adicionar um comentário
4 respostas
Solução escolhida
If your Bajaj Discover motorcycle is not starting, here are a few things you can check:
  1. Check the battery: Make sure the battery is fully charged and that all connections are clean and tight. If the battery is old or weak, it may need to be replaced.
  2. Check the fuel: Make sure there is enough fuel in the tank and that the fuel valve is turned on. If the fuel is old or contaminated, it may need to be drained and replaced.
  3. Check the spark plug: Make sure the spark plug is clean and properly gapped. If it is fouled or damaged, it may need to be replaced.
  4. Check the air filter: Make sure the air filter is clean and not clogged. A dirty air filter can restrict airflow to the engine and cause starting problems.
  5. Check the carburetor: Make sure the carburetor is clean and functioning properly. If it is dirty or clogged, it may need to be cleaned or rebuilt.
  6. Check the ignition system: Make sure the ignition system is working properly. This includes checking the ignition coil, CDI unit, and other components.
If you are not comfortable performing these checks yourself, it may be best to take your motorcycle to a professional mechanic for diagnosis and repair.
Esta resposta foi útil?
Pontuação 7
Try kick start maybe your battery is worn out
Pontuação 3
Find your spark plug location. It's may be right and left side of the engine's nearby top side. Their have an adaptor to connect spark plug and that wire. Remove adaptor and directly keep the wire near by engine and kick the vehicle to start. It may cause to electrical shock. So do it carefully. And check any spark is present or not....
Pontuação 0
Start with the basics 👍
  • Check battery (most common, does it crank?)
  • Fuel on + not empty
  • Kill switch off
  • Listen: no crank = battery/starter, cranks but no start = fuel/spark issue
If it’s been sitting, fuel or plugs are usually the culprit.
Pontuação 0
Adicionar a sua resposta
Geoffrey Ouko será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 50
Últimos 30 dias: 241
Ao todo: 8,192
