PowerON "No Signal" screensaver is scrolling ghost image rt side only
Upon poweron i get the banner at the bottom with all the TV program onboard options like youtube, netflix, etc... Once that leaves the No Signa. HDMI3 check cable etc... banner displays.. BUT the right side only appears with grey ghost image bar. I have video if need
Version: UD04
Update (02/25/2023)
@oldturkey03 hey there I think you resolved an issue for me once before …
Yes you are correct on the model of the tv
Here is a video of the issue
The guy I got the TV from replaced the main board (component)… So I am thinking t-con or buffer
Esta é uma boa pergunta?
3 comentários
@flex4705 post some images or a short video with your question. Adicionar imagens a uma pergunta já existente This could be a T-con or a main board issue. If you have already removed the back cover from your TV, post some pictures of your boards with your question as well.
Just to verify, your TV is a Samsung UN75JU641DFXZA 75-inch 4K UHD TV
por oldturkey03
@flex4705 when you first turn your TV on it shows you the installed streaming channels etc. then it turns to the no signal screen?
Did you try all the other video inputs? Same issues? If you enter these keys into your remote, does it get you into the setup menu?
Info==>Menu==>Mute==>Power If so, try a reset.
por oldturkey03
I can get into the setup menu and I have not tried OTA signal. I do have the Tv connected to wifi… I will provide some images and videos. I can see some horizontal lines and some green hues …
I will try a rest if I can find it… I don’t have the remote but able to maneuver with button on tv through menu.
por Drexter Evans
