Why the light at frieze and fridge it’s blinking and not keeping cold
Why Light at freezer and fridge blinking and frozen and fridge it’s not cold
Esta é uma boa pergunta?
The blinking light in the freezer and fridge is an indication that there is an issue with the appliance. It's possible that there is a problem with the cooling system or that the temperature control settings are not set correctly.
First, check if the temperature settings are set correctly for the fridge and freezer. Make sure that the vents inside the appliance are not blocked by food items or ice. If the vents are blocked, remove the items and allow the vents to properly circulate air.
If adjusting the temperature and clearing the vents does not work, it's possible that there is a problem with the cooling system. This could be due to a faulty compressor, condenser, or evaporator fan. In this case, it's best to contact a professional appliance repair service to diagnose and fix the issue.
Esta resposta foi útil?
Same problem. Fridge temp blinking. Top part not cooling. And mine just came back from repairs. My 15 year old fridge still working perfectly though.
Press and hold the LIGHTING and FREEZER button at the same time. If that doesn’t fix it, press the ENERGY button and hold it for 5 seconds, then press and hold the LIGHTING and FREEZER button for 5 seconds.
Últimas 24 horas: 49
Últimos 7 dias: 328
Últimos 30 dias: 1,523
Duração total: 22,215
I am also having this blinking "WiFi" light problem too and I am pretty sure that something is not working because the freezer stopped all of sudden. But that person on 800-Samsung (someone located in Philippines and don't answer your questions straight) tried to convince me that the problem is just some basic settings and kept reminding me that if the technician come over and found out that is not something broken, I would be charged extra for that. Then planned someone to contact me the next Wednesday (I called on the previous Friday). Thank you, Samsung for your Two-Year Warranty. Now I am really missing my 10-year-old fridge that was just hauled away 4 months ago. That 10 year old fridge worked much better than this Samsung junk + a so-called 2 year warranty.
por Peng Zhao
Same problem . Our freezer's temperature blinks after a recent blackout ! What do I do ? Will it stop after it gets colder inside the freezer ?
por Hasti Salehi
I am very sorry I bought that piece of junk Samsung frezer/fridge.
Is a waste of money.
por Edgardo O Matute
