Blinking Light on Camon 11
The blinking front light is stuck on constant lighting and will not go off even when i switch off the phone. Should it be hardware problem causing that
Esta é uma boa pergunta?
If the blinking front light on your Camon 11 is stuck on constant lighting and does not turn off even when you switch off the phone, it could be a hardware problem. There may be an issue with the phone's circuitry or with the LED light itself. You could try a few things before taking the phone to a repair shop. First, try removing the battery and SIM card and leaving the phone off for a few minutes. Then, reinsert the battery and SIM card and turn the phone back on. If the issue persists, try performing a factory reset of the phone to see if that helps. If the problem still persists after trying these steps, it may be best to take the phone to a repair shop to get it checked by a professional.
Esta resposta foi útil?
Check breathing light in you setting
Most of the time the problem is attached to loss of knowing your setting so check "breathing light" in your setting
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 367
This question was migrated from https://meta.ifixit.com/Answers.
por iRobot
