Ir para o conteúdo principal
The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
Will not detect or read and SD card
It just keeps reading SD card error
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi
Sometimes cleaning the SD card slot with some isopropyl alcohol and a toothbrush can help to resolve this issue
Also the Hero 5 was known for the water resistance being a bit of a hit or a miss so if it has been exposed to water I would recommend using this guide to check the device for water damage
Here’s a disassembly guide
GoPro Hero5 Black Motherboard Replacement
Once again isopropyl alcohol is good at cleaning corrosion but water damage can sometimes need professional work
I would also check the formatting of the SD Card,make sure the GoPro can read it:-)
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 1
1 comentário:
Try another SD card before you get to the point of disassembly, i've had some SD cards fail in odd ways like that before!
por
Adicionar a sua resposta
tourette88 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 319
