How to place the mouse battery spring terminal properly
Mouse broke apart and I'm trying to slot in the battery spring properly to no avail
Esta é uma boa pergunta?
Hi
If the spring is on one side of a compartment do the opposite on the other compartment
It would be diagonally across when correct
In terms of how it should be wired it should be wired + to -
It should have a positive and a negative on the board
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 60
1 comentário
@j1nju that is the negative contact. Post a clear image of the negative side of your battery space,so we can see what you see. We need to see the other side and a bit better lighting :-)
por oldturkey03
