How do I disable the digitizer on the screen?
i need to do this bc the touch screen is pressing things without me doing anything
Esta é uma boa pergunta?
Hi Guy,
There may be an easier way than opening up the computer. According to Lenovo, you can enable a key combination that will toggle the enabling of the touch screen.
How to Disable the Touchscreen on a Chromebook - Lenovo Support IT
The gist of it is that you enable keyboard debugging shortcuts, then pressing Search+Shift+t will turn the touch screen function on or off. Here's the relevant text.
- Launch the Chrome browser and type the following path:
chrome://flags/#ash-debug-shortcuts- Locate the debugging keyboard shortcuts and click Enable. Disable is selected by default.
- Select the Relaunch Now icon to restart Chrome to apply the changes.
- After logging in again, perform this keyboard shortcut.
Search+Shift+t- This allows a way to toggle the touch screen on or off.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 896
1 comentário
@robux you could possibly disconnect the ribbon cable. Your digitizer suffers from Ghost Touch and will have to be replaced. Is your Lenovo the 300e model?
por oldturkey03
