Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Perguntas Visualizar todos
MacBook Pro 2017 (A1708) unable to see OWC Aura Pro NT SSD
My MacBook Pro 2017 (A1708) SDD has been giving me issue, it works intermittently. When it works it works as expected and other times boots up to a flashing question mark folder.
I updated the machine to MacOS 13.2 and swopped out the SSDs and was not able to see anything in disk utilities. The drive does not pick up at all.
Reinstalled the old/original Apple SSD and the machine works the same as before.
Any advice will be appreciated, thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
What is the version of macOS which you are working with? Both the original SSD as well as what you installed onto the OWC.
This sounds like a file system type of issue.
Esta resposta foi útil?
Pontuação 0
9 comentários:
I had macOS Ventura 13.2 installed on the original Apple SSD. I was unable access the OWC drive in disk utilities, using command + r or with a bootable USB.
Not sure if I am missing a step to get the drive visible in disk utilities.
por
@glegrange - The version of macOS on your bootable USB drive maybe the issue! What is it?
por
@danj macOS 13.2 as well, the same has installed on my machine.
por
@glegrange - This is quite odd! So both the original and thumb drives are running the same macOS version.
Often we see issues when mixing file system versions like Sierra or older (HFS+) Vs anything newer High Sierra and newer (APFS). The systems firmware gets upgraded so it can boot from the newer OS and Disk Utility also gets a few tweaks.
Have you spoken to OWC? I would do that you might have a bad drive here.
por
@danj I have returned the SSD and waiting for the refund to be actioned. Seems a bad drive is the only explanation.
por
Exibir mais 4 comentários
Adicionar a sua resposta
Gareth le Grange será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 168
