Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
How can I fix NFC?
Hi!
I think the NFC of my phone is broken : I use it for Apple Pay and to check my glucose (freestyle libre sensor) and it doesn't work for two days …
I have some questions :
- Is there something else to check or to change except the antenna?
- Where can I find a repair guide to do it?
Thanks+++
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
What troubleshooting steps have you followed so far? Have you attempted to power cycle the device?
por
Adicionar um comentário
1 resposta
Hello Camcam,
the NFC loop is built identically to the model 8. The important thing is why it stopped working. Immediately before noticing that NFC is not working, did your phone have a fall or similar incident? All this, from the point of view of diagnostics, is important and speeds up the whole process.
The antenna problem never occurs by itself. It is usually related to a fall or wather damage. In fact, all you can do (assuming you have experience with a screwdriver) is to remove the screen and check the continuity of the antenna line from the motherboard to the internal antenna at the top of the housing. In case of an incorrect reading, you can replace the 1-st step antenna. The cost is about $2-5 if you decide to do it yourself. On the other hand, you can test ApplePay in store when paying before and after factory resetting your phone. Sometimes it happens that NFC communication hangs the entire subsystem due to compatibility problems with various devices in this technology. The third and final option is to find a good repair shop where the technician "took his teeth" (or "ate his teeth" - people say that in my location) on repairing the motherboard of Apple devices. You're sure to find a few of these places depending on your location.
Esta resposta foi útil?
Pontuação 0
2 comentários:
My iPhone SE is having the same issue, is there a picture anywhere of the NFC antenna and what contacts to check?
por
I'm sure you'll find one somewhere online.
por
Adicionar a sua resposta
Camcam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 3,928
