Ir para o conteúdo principal
Oracle VM VirtualBox is a type-2 hypervisor made for x86 virtualization developed by the Oracle Corporation.
1 Perguntas Visualizar todos
erro de virtualbox 0x80004005 2022.4
Não estou conseguindo resolver esse erro do virtualbox, já procurei no youtube e procurei na internet mas não encontrei como corrigir esse erro:
Nome da VM: kali-linux-2022.4-virtualbox-amd64
A sessão VM foi abortada.
Código de Resultado:
E_FAIL (0X80004005)
Componente:
SessionMachine
Interface:
ISession {c0447716-ff5a-4795-b57a-ecd5fffa18a4}
o sistema que deu erro é o kali linux
sempre que eu abro o sistema ele aborta
Translation
I can't solve this virtualbox error, I've looked on youtube and looked on the internet but I couldn't find how to fix this error:
Name of VM: Kali-linux-2022.4-virtualbox-amd64
The VM session was aborted.
Result Code: Result Code: E_FAIL (0X80004005)
Componente: SessionMachine
Interface: ISession {c0447716-ff5a-4795-b57a-ecd5fffa18a4}
the system that gave error is kali linux whenever i open the system it aborts.
Esta é uma boa pergunta?
Pontuação 1
6 comentários
@jmehnert you are the Kali Linux Guru :-) Anything you can make out of this?
por
Not of the top of my head, but I can do some digging and find out
por
Found the answer. I also took the liberty of translating the question along with the error the OP got.
por
@jmehnert GReat. I usually do not translate anything from the OP since it's kind of their house. After all this is the Portugues section and I am a guest here. So I should at least learn to speak all those languages :-) But that is just my take on this. I usually just translate my answers and post both the English and the translated version. Again, do not take this as any criticism, it's just the way I do it.
por
@oldturkey03 oh haha, that would explain a bit. I amended my answer to include a translation for OP.
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
I did some digging and found that the error code itself is given when their are problems with the VirtualBox app, configuration files, or potential hardware-related issues. I was able to find this article by Help Desk Geek that explains it very well. But, to give you the spark notes of what you should try first...
  • Make sure virtual box is up to date (Current version is 7.0.6)
  • If you are on Windows, you are going to want to restart Windows Hypervisor by using the two codes below this bullet point
    • bcdedit /set hypervisorlaunchtype off
    • bcdedit /set hypervisorlaunchtype auto
  • If all else fails discard the VM's saved state (The VM equivalent of turning it off and back on)
The article has a few other tips to try, but these bullet points are going to be your starting point for troubleshooting.
Tradução em português
Fiz algumas pesquisas e descobri que o próprio código de erro é fornecido quando há problemas com o aplicativo VirtualBox, arquivos de configuração ou possíveis problemas relacionados a hardware. Consegui encontrar este artigo do Help Desk Geek que explica muito bem. Mas, para lhe dar a versão resumida do que você deve tentar primeiro...
  • Certifique-se de que o programa VirtualBox esteja atualizado (a versão atual é 7.0.6)
  • Se você estiver no Windows, você vai querer reiniciar o Windows Hypervisor usando os dois códigos abaixo deste marcador.
  • Se tudo mais falhar, descarte o estado salvo da máquina virtual (o equivalente da VM a desligá-la e ligá-la novamente)
O artigo tem algumas outras dicas para tentar, mas esses pontos serão seu ponto de partida para a solução de problemas e peço desculpas pela tradução tardia.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
cacique_Gamerr será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 33
Últimos 30 dias: 142
Duração total: 1,073
