Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Pink lined display screen
Has anyone seen this before? I have the A1708 model.
Laptop has not been damaged or dropped. Worked fine and this randomly happened. The screen appears to come on around the 45 degree angle sometimes, which leads me more in the direction of some connection inside with the screen? Any guidance and feedback would be appreciated!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sadly yes, Apple had a bad run of displays. Most failed within the first year warranty. I’m surprised yours held out four years!
When the T-CON board logic heats up it causes this issue. I would visit an Apple Store, see if they will still cover the repair as a warranty exemption. See if you can get them to cover the labor cost at least.
If not, it’s going to be costly! MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 13" Function Keys 2017 Display Assembly Replacement
Imagem de Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096.
Produto
$444.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Traci Babcock será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 89
