Ir para o conteúdo principal
Repair guides and support for a wide range of clocks.
18 Perguntas Visualizar todos
The wall clock glass is broken
The front glass of my wall clock is broken, I haven't found a separate glass to replace the broken glass, how can I fix this
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I need to replace a square convex glass face for wall clock. Can't seem to find one. Help!
por
Adicionar um comentário
1 resposta
Solução escolhida
Black princess, Most places (businesses) that work with glass, window works, places like that, will custom cut glass to your needs. All they need is the thickness of the glass and the diameter it should be.
It does depend a little on whereabouts on this tiny blue rock you’re located, but most countries and larger cities have such a place (even here in Micronesia (erhmm.. Norway :P )).
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Black princess será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 71
Duração total: 724
