Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
226 Perguntas Visualizar todos
Why is my Wi-Fi not working?
I tired to reset the pram and smc and none of that worked and I downloaded and new version of macOS Big Sur can someone tell me what’s going on with the Wi-Fi?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Do you see the WiFI symbol in the top right of your menu bar? If you do click on it a drop down list should show up do you see a listing? Do you see your WiFI access point (AP) listed? Select it you may need to enter your WiFI access password.
Esta resposta foi útil?
Pontuação 0
2 comentários:
There was no listing of any wifi networks and no access point and when I tried to open wireless diagnostics is would not open also wifi doesn’t show up anywhere in system preferences what should I do?
por
@Jia Liu - This series uses an onboard chip for both Bluetooth & WiFI.
At this point it’s likely it’s damaged! This would require someone with micro-soldering skills and access to the needed parts. Or, just replace the logic board. Do keep in mind the power/TouchID button is married to the logic board, you can’t mix them up!
por
Adicionar a sua resposta
Jia Liu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 29
