Ir para o conteúdo principal
Model A1288 / 8, 16, or 32 GB capacity
451 Perguntas Visualizar todos
need apple iPod ID
bought it off someone else and need my own ID account cant get theres off dont no there password theyve moved
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Pergunta mais útil
Hey Tove,
If you go into the settings, does it allow you to add a new account to the device? You should be able to change your account to the master account.
Hope this helps!
Esta resposta foi útil?
Pontuação 1
Here's another way that might work for you:
Open your iTunes and all the way in the bottom select to sign out. When you sign in, it should ask you for the account, here you select your existing personal account or make a new one.
Good luck :)
Pontuação 1
I would just restore you iPod, that way it will remove everything else that's there's to.
Pontuação 0
Adicionar a sua resposta
Tove será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 561
