Ir para o conteúdo principal
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
Which SSD enclosure works best with this model?
I recently just bought this enclosure. External M.2 SSD NVMe Enclosure Im wondering if this is compatible with my MacBook Pro 2012 so i can get the data off of it or which enclosure i would need to get this working. Thank you.
Update (02/04/2023)
Unsure if my wording is wrong but the SSD i have is from a MacBook Pro 2012 retina. I’m trying to get the data off of it And Im wondering if this enclosure will help me do that once i plug into a new MacBook.
Imagem de Use an M.2 SSD as an external drive in this enclosure. USB 3.1 transfer speeds up to 10GB/s
Produto
$29.99
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Unfortunately That one won't work due to apple using their own Proprietary SSD Connector.
But OWC has one!
Part: OWC Envoy Pro External SSD Enclosure (Mid 2012 and Early 2013 Macs)
Imagem de Make your factory installed Apple SSD into an external SSD drive. Transfer data to a newly installed internal SSD or keep the original drive as added external storage.
Produto
$69.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
dayronh3 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 210
