Ir para o conteúdo principal
Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
How do I identify my specific model of Surface Pro?
How do I identify my specific model of Surface Pro? I tried the System Information but it says only Surface Pro. Under System SKU it shows Surface_Pro_1796. I need to replace the battery and want to order the right one, the first time.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
Hello, if you put your serial number in this link -> Check Warranty Page - ROBO SelfServe Portal (surface.com)
It should come back with the exact model.
To find your serial number you can use this microsoft guide -> https://support.microsoft.com/en-us/help...
Esta resposta foi útil?
Pontuação 6
1 comentário:
Thanks for the response. I found the serial number in the Surface app on the device, it's a Surface Pro 5th Gen which I also found out is AKA Surface Pro 5. Thanks again for the quick response, now I know which battery to order.
por
Thank you
The link works fine
Pontuação 0
Adicionar a sua resposta
Keith Ball será eternamente grato(a).
Visualizações:
Últimas 24 horas: 51
Últimos 7 dias: 334
Últimos 30 dias: 1,476
Ao todo: 46,244
