Ir para o conteúdo principal
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
What to use to remove adhesives or glue?
Need help. Im trying to fix my watch but I can’t remove the screen off the watch frame. I think the guy who replaced the battery used a glue to re-attached the screen back. Tried to heat it up and used adhesive remover but did not work. Please help. Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hello, what adhesive remover did you use? I suspect the last person may have used super-glue or something similar on the watch, so something that can dissolve that would likely help you quite a bit. At worst, you may have to sacrifice the display to get a good point to pry from unfortunately.
Esta resposta foi útil?
Pontuação 4
1 comentário:
I was able to removed the Face. I used Bob Smith debonder, it worked perfectly.
por
Adicionar a sua resposta
jory antiporda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 376
